Rogers Web Site
Date:  7-4-2013
Brief Description:  Fuel tank skins
I removed the fuelt tank skins from both spars and worked on the left tank, removing the stiffeners, and the blue protective film from the inside of the left tank and removed the film from the rivet lines on the outside of the tank, that's when I found the corrosion that can be seen in photo 1.
Left wing tank lower skin, corrosion on the edge.
Left fuel tank skin
Left fuel tank skin
