Rogers Web Site
Date:  6-16-2013
Number of Hours:  2.50
Brief Description:  Right wing L/E
I clecoed the right wing leading edge to its respective leading edge ribs. I basically held it in shape while my wife put some of the clecoes into it, so I could finish clecoing the remaining ribs in place. I started with the centre rib and worked my way out to the ends from there, clecoing each suscessive rib. Later when I cleco this assembly to the spar, I'll cleco the innermost rib in place as that needs to have all it's rivet holes drilled when in its final postion with respect to the spar and L/E skin. after marking the flange of the innermost rib down it's centre to help locate where the rivet holes need to be drilled.
The garage is getting hot, even with a fan running these days.
Right wing L/E
Right wing L/E
