I clecoed the wing walk strengthening plate to the inner right wing skin made sure the position was right, and drilled the rivet holes through both parts clecoing the wing walk plate as I went to keep everything straight. I then clecoed the both upper skins to the right wing frame. I found that I hadn't allowed enough space at the wingtip end, to cleco the outer skin to the frame. As the skins are about 1/4 longer that the wing. I just added some more washers to the bolts at the wingtip to act as extra spacers. Tomorrow the top skins for the left wing frame.
The right wint with the top skins clecoed into place
