Rogers Web Site
Date:  4-10-2013
Number of Hours:  4.00
Brief Description:  Riveting the left flap together
I riveted the ribs to the top skin, which was a bit of a squeeze, as there isn't a lot of room in there. I then drilled the 706 to the end rib deburred and edged the 706. I used a 1/4 bolt to locate the platenut for the flap actuator correctly and drilled debured and riveted the platenut to the inside of the rib. I then finished riveting the 706 reinforcement plate to the end rib. I riveted the end ribs to the skin, but had to use some blind rivets for some of the holes near the trailing edge, as I just could not get my bucking bar in such a small space. Next rivet the spar to the top and bottom skins, then it's done.
The left flap nearly finished
