I fabricateda fillet and replased the horrible tab bends on the elevator skin, it looks a lot better.
Then I aligned the trim tab and the elevator and drilled the hinge on the elevator side, keeping a very close eye on the alignment, riveted the hinge in the elevator and fitted and bent the hige pin to suit the plans
Arg the horrible bend, which I cut out and replaced
