Brief Description: Riveting the HS skins to the frame
Frame was ready dimpled etc. Dimpled, deburred, edged the skin.
Clecoed the HS skins to the frame. While riveting the rear ribs and front spar I foundf it easier to release the rearmost three clecos so I could get my arm inside the HS, obviously the tips were a little tricky also, because of this. When not riveting I placed the rear spar in position and clecoed it so the front spar wouldn't sag under the weight of the assembly
