Brief Description: Fuel vent installation & fuselage side hole.
I enlarged the holes for the fuel vent lines and installed the bulkhead fittings. I went to Aircraft Spruce and picked up a tube cutter and a 1’ knockout punch for the rubber grommet that the fuel supply line goes through the fuselage. I also enlarged and prepped the hole for pitot tubing and electric wire runs.
