1. Lining both rear canopy skins with 1/16th-inch-thick, waterproof seals 2. Re-clecoing both rear canopy skins into place 3. Riveting both rear canopy skins to the rear top skin and fuselage side skin 4. Adding a bead of clear (actually more like translucent) DAP Alex Plus silicon latex caulk along the tops of the rear canopy skins. 5. Riveting the rear canopy skins to the rear canopy bubble. 6. Attaching the rear canopy bubble to the aft rear frame using self-tapping screws with tinnerman washers.
I'm very happy with the look and fit.
Rear canopy skin riveted in place.
Rear canopy skin and bubble after final installation.
Looking through the bubble you can see the waterproof seal and caulk bead along far side top.
