I block sanded the lines with 400 grit initially, then block sanded the remainder of the wing with 500 grit sponge back. I'm pretty happy with the way it has come out, but I cut through slightly in a few places. These will be easy to respray as a tack coat before removing the mask and applying the 2K clear overall.
