Swinnys 4 Place Bush Explorer
BushCaddy L164
Priming the inside surface of the bottom skins
Today I removed the bottom skins and deburred all rivet holes. (no small task).
I then prepared the inside surface for priming and applied the primer.
I then deburred all holes in the wing framework, bottom skin areas, and did a final clean out and inspection of all bolts in the wing area.
Replaced the skins ready for final rivetting
Heading off to Africa for the next 7 weeks so no work for a bit !
Bottom skin primed
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
