Brief Description: Zip-tying firesleeve around the oil cooler return
A clean-up task I finally knocked out: Replacing the temporary plastic zip ties holding the fire sleeve in place on the oil cooler oil lines. I replaced them with stainless steel zip ties. The fire sleeve is really there to protect the lines from rub and chafe, not to insulate them, so these simple stainless ties should do the job.
