Hong Kong Waiex
Waiex
WIX-W14
Left Main Spar - Spar Caps & web - then assembly
"I cleaned the spar caps and the main spar web. I then degreased after scotchbriting and then 2 coats of primer was applied.
I then assembled the spar with all angles located and what ones that required bolts and screws were installed. Rivetting to be done next."
Waiex Home
612
Ailerons
Ailerons
Flaps
Flaps
Front Fuselage
Kit Delivery
Rear fuselage
V-Tail Stabilators
200
Workshop
