Ok, so it has been a looooong time since last update again. I've certinly been working on the -10 on and off over the last few years but I just never remember to add anything into a log anymore. I'm going to try and get better about it going forward. So one of the things I ended up doing was switching from the Plane Power alternator to a B&C. Main reason being fitment with my cowls and intake choices. So this required adding in the external voltage regulator. Thankfully I had some room under the panel where I once had the lightspeed controllers. It was a pain but got it mounted. Also added a couple of mounts for some things in the engine compartment like the e-mag required blast tubes
