Went thru the drawings and the engine sensor harness. Ohmed out and labeled the wires. Removed the few unnecessary wires and corrected the harness for electronic ignition (moved the RPM sense from pin 32 to pin 33). Added the wires for a sceond current sensor for the SD-8.
