Finished fitting the fiberglass fairing on the tail cone. Checked for proper clearances and looks good. Then worked on some of the revistions that Van's has sent out. Changed the nut plates that were called out in the revistion on the battery holder. also installed the return fuel line union fitting on the bottom shelf of the panel.
