I set up the aileron push rods earlier in the build but still had to fit the control tubes.
Followed the manual with the alignment tool and whilst some of the fittings were fiddly it went well and the travel was within limits. having bagged the fittings when I took off the ailerons with a drawing made life a lot easier.
Had a slight chafe on the left hole where the aileron pushrods enter the rear spar so had to file out about 1/16".
