Vans RV-8 G-JBTR
RV-8 Build Log
Baggage Door 1
Made the baggage door as per plans and found the fit to be pretty good with the exception of the outboard skin which sticks up quite a bit.
Before I edge roll/bend it I'll post on VAF to see what others have done.
I posted on VAF and the consensus was to hand seam/edge roll the door edge. So I did and the result is quite acceptable.
The hinge and latch pin block will not be installed until the forward skin is finally riveted on.
Baggage Door Skin Edge
Edge seamed/rolled
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
