Made an aluminium plug to seal off the inside of the rotor shaft fromair and resulting corrosion. Put a threaded hole in the centerof he plug to be able to install it inside the shaft with BJ Weld. Once it is set up, then the bolt is removed and a screw is installed using a sealer to make the connection air tight.
