Time to align the upper rotor shaft bearing using shim stock. Also made up an adapter to be able to check the alignment with a dial. Eagle provides a collar to measure alignment, but using a dial is certainly the better way to go. Could align the bearing housing within 1/1000", which is well in Eagles requirements.
