GOTTFRIED'S WEB SITE
Date:  1-5-2019
Number of Hours:  3.00
Brief Description:  TR drive shaft installation
Installed the drive coupling onto the transmission shaft. I had made a steel bushing earlier with an OD of a Letter D dill and an 7/16 ID. This bushing will keep the 7/16' drill centered when drilling through the coupling. The bushing is then removed and the hole is opened up with a letter D drill.
coupling holes drilled using a bushing
