Used a lazer to align the tail rotor to the centered transmission. Cut some washers out of shim stock untol the tail rotor transmission was installed at the correct angle so the lazer would hit the center of the transmission input shaft. The lazer can be deflected easily by putting any loads on the Helicycle tail section.
