GOTTFRIED'S WEB SITE
Date:  11-4-2018
Number of Hours:  5.00
Brief Description:  drilling rotor tip holes for later balancing
Drilling a hole into the rotor spar is not something shown in the video, but it seems all builders put them in to make it easier to balance the rotor blades. I wanted to make sure that these holes were drilled perfectly straight and at the intended location, so I build a small gig and bolted it to the spar of the rotor. Worked out as intended and I drilled the hole about 1.5" deep and then tapped it 1/4"-20 and put in set screws, which will be locked in place after the blades have been balanced.
marking hole
marking hole
home made drill gig
home made drill gig
taping the hole 1/4
taping the hole 1/4"'-20
