GOTTFRIED'S WEB SITE
Helicycle
Rotor system
3-31-2018
end plugs
Next I drilled the holes for the end plugs. This is a more tricky operation, since the aluminum is much thinner than att he root of the rotor where all doubles are installed.
The off-set patterm for drilling can be seen in the pictures.
ff-set pattern so screws would not hit eachother
root side finished on both blades
Helicycle Home
984
Cabin
43
114
85
Electrical system
77
235
Frame
Fuel system
General
Landing gear
Rotor system
63
217
Transmission
