Next I started tomake theplugs for the rotor tins. glued the provided plywood pieces together as instructed and shaped them to fit he rotor tip. Made quitea few to get it just right. They sould not be too lose, or the blade will be deformed when the screws are tightened. They als can not be too tight. After many test ittings I finally got it right.
getting he adhesive out of the corners to install plugs
