time to finish the rotor blades which were returend from Eagle R&D. Started to make a first plug for the root side of the blade. Eagle R@D roposed to use plywood, but sind the centrifugal forces on the root of the rotor blade are low, I used clear pine wood, as used by BJ in the video.
