GOTTFRIED'S WEB SITE
Date:  4-17-2017
Number of Hours:  3.00
Brief Description:  TR mounting
Drilled the D size hole through the TR coupling using my special home made drill guide. After opening up the hole with the D Drill the bolt fit nice and snug.
Next i removed the % bolts from the RTone at a time and drilled the bolt hears for saftety wiring with a 1/16" drill.. I also drilled the holes into the pitch horns and slider, but dd not install the saftety wire yeat. This will be done on final assembly.
Using my drill guide to pre-drill hole
drilled and saftey wired TR bolts
rilled holes for later saftety wiring
