GOTTFRIED'S WEB SITE
Date:  4-15-2017
Number of Hours:  3.00
Brief Description:  assembling TR
Today I made the tamplate to measure TR blade deflection. Just cut it out with a sabre saw and filed to to shape. Easy project!
Next I cut the 4 ball joint fittings to the required length and assempled the scissors and all linkages to the Tail rotor.
Adjusted the linkages to see if I had all the clearances and the deflection range. Blades moved from -8 degrees to +18 degrees, which is what they are supposed to do.
checking pitch angles
linkages are assembled
