After preparing all surfaces I mixed the epoxy at ratio 2:1 and mixed in the glass beads. Then applied epoxy to doublers and located them on the blade, installed the bolts, the wood sticks and clamps. Wiped off the excess epoxy, cheked thickness with adhesive and wated for material to cure. 6 hours later i started to take the clamps of and leaned up the doublers and removed exess adhesive.
