Started final assembly of the ship. removed all components down to the bare frane and final installed transmission. Watched BJ video step by step to make sure I did not forget anything and torqued all bolts to specifications. Installed the chip detector and safety wired it. Installed oil cooler and lines. Will have to buy a new oil feed line to the oil cooler, because one of the AN4 fittings will only thred on the nipple about 1.5 turns. Ordered new oil line so i can fill in oil and test for leaks and proper function.
Also started to final install cyclic and collective controls as well as directional controls.
