Installed the slider bracket today. Used my lazer tool to align the bracket perfectly in line between rotor shaft and tail rotor coupling. The fishing line, as suggested by Eagle, had too much measring tolerance. The bracket leans about 7 degrees to the right when flush mounted on the hood bracket and I will have to come up with a angled spacer to compensate. Drilled the 4 holes.
