Watched BJ's video on cylic control assemly a fe times and sorted all the parts needed. Cut the spherical fitting 3/8" fot the front of the cyclic control tube. Fit the front plug into the tube and drilled the 3/16' hole to secure it in the tube.Drilled the holes in the casting to mount the cyclic control stick and for thepush rod. Drilled the 1/8th" holes into the slider for the saftety andsprings and also drilled the bolt heads so they can be secured with safety wire to the slider.Then I assembled the casting to the cyclic control tubeand installed the assembly into the airframe to checkfor fit. All fits well and there is no binding.Next I will assemble the mixer.
