A few dings happended during the painting process. One scuff on the HS because it hit the rotisserie stand, 1 thin clear coat area and 2 nicks (hanger rash happens).
The process is pretty straight forward. For the nicks and scuffs, sand the area, spray base then clear coat. Don't tape or you will have an edge line. The overspray will wet sand off of the existing non sanded clear coat.
The photo shows the repaired are on the VS. There was a nick about 2 inches long where the LE of the VS banged into the garage door after wet sanding. I was sick, but it turned out perfect.
