JoeNelsens Web Site
Date: 9-27-2016
Number of Hours: 8.00
Brief Description: CRAP!!!
1)Well, I did get it started and it did run pretty well and nothing broke beyond repair, BUT it only had compression on 1,2 and 4. All of them were well above 75/80. Old #3, had zero, and in zippo,,otherwise known as nothing recordable. If you dont count the large hiss of air from the head gasket/shim area. 2) Just what I was thinking...What happened? Dont know at this stage. sort of looks like a bad head? or cylinder? or something else? 3) This is #4, and it was holding enough compression to not be suspect. Iwas surprised that it too was leaking
I did talk to the factory and they had not heard of this problem before. Well, they cant say that anymore! :ike I had indicated to myself when I tore it apart, ###$$$&&!!??!!!, and more!
HUMMM...
Yeah...what happened?
Both heads?
