Brief Description: VERT STAB NEW REAR SPAR INSTALL
(1) I carefully transfer drilled the new rear spar on to the vertical stabilizer frame. (2) Removed, and preped for priming ( deburr, polish and rough surface) (3) Primed the new rear spar and set it aside . (4) Transfer drilled the skin stiffeners to the side skins of the vertical stabilizerand prepped them for priming . (5) primined the skin stiffeners in prep for installation.
