Plans: 1. Complete the aileron build. Status: About 90% done. The ribs have been riveted in place. The scalloped trailing edge is in place. The aileron hinges have been temporarily riveted in place to support addition of the control arms. The ailerons were affixed to the air vehicle. The aileron ends remain to be tailored into the wing tips. I also took a stab at adding the control cables. In doing so I learned that the cables are too short to embed fully into the wing. As supplied you must route them external to the upper wing. I will probably substitute some longer cables to achieve a more finished result.
