I mark on the W-704 the screw locations at each unused rivet space on the bottom flange of the W-710 root rib. I then marked a straight line from the hole location toward the wing tip and I made a measured mark 3 inches outboard from the intended screw location. This will allow me to measure back to the same point on the overlapping F-776 fuselage skin.
