Brief Description: Installed cotter pins to engine mounts.
Today I installed the washers and cotter pins to the engine mount castle nuts. I tightened the bolts till the bushing bottomed out and then tweaked the nuts ever so slight to get the bolt hole aligned with the castle nuts. I inserted the cotter pin from an easy access point and then rotated the entire bolt and nut assembly so I could access the other side of the cotter pin for bending. Now to figure out what goes where on the engine?
