Today I installed the voltage regulator, which took longer than it should have. It wasn’t apparent where it should be installed. I ended up bolting it to the aft side of the sub-panel on the pilot side. I also wired the regulator but still need to pick up some 18 AWG to finish the job. I soldered the low voltage warning light with 22 AWG and attached it to the regulator. I am just starting the wigwag flasher and hope to be finished with item tomorrow.
