Noted some small oil leaks that appeared to be originating at the weld joint on the oil pan. Cleaned the weld joint and applied "Ultra Black" silicone sealant to the suspected leak spots.
Installed the 100 Watt heat pad to the bottom of the oil pan. Sealed the edges according to the installation instructions.
Installed cotter pins on the prop nuts. Installed the front spinner locating plate. Installed spinner.
Installed rubber sealing strips on the front horizontal edge of the canopy arms.
Set up the Dynon ADAHRS airspeed limit points, So, Vne, Vfe, etc.
