Threaded the ports in the manifold for the primer, manifold pressure, and intake temp sensors. Installed the manifold on the engine. Installed the cowling. Connected the Dynon GPS receiver.
Took airplane outside and test ran the engine. The mixture distribution was much better than with the previous manifold, but one cylinder is running too lean. Not sure why. Cylinder cooling is good.
