Added 1" foam over the lower part of the cowl to cover the exhaust system. I used up to 3" of foam over the lower center to insure sufficient clearance between the lower cowl and the exhaust pipes. Added spray foam to the edges of the 1" foam strips to fill in and allow smoothing to final shape.
