Sealed joints in the cooling baffles with butyl rubber sealing material. NAPA P/N 4195 glass sealer. Installed a 1" diameter flanged air outlet at the top rear of the air box to supply cooling air to the enclosure around the fuel filter and fuel pumps.
Put the 1/4" and 1/8" thick propeller crush plates in the lathe and turned the outside diameter down to 5.45". This was needed so that the crush plates will fit on the Warp Drive prop hub between the heads of the blade clamping bolt heads.
