Trimmed the fiberglass layup duct added yesterday to the top cowl. Tested fit on the bottom cowl. Decided that teh ducts needed more strengthening on the edges. Added two or three more layers on the weaker edges using high temp epoxy. Set outside to cure in the sun.
Measured the rear baggage shelf for carpet. The carpet will need to be in two or three pieces cut from the 36 x 72" piece I have. Cut carpet to fit and glued in the laregest piece. I'll put in the rest tomorrow morning when it is cooler.
