Bills Web Site
LNC4
Buffing + misc
Finished buffing the fuselage. Looks pretty good...not perfect, bur pretty good.
Installed washers and nuts on rudder hinge bolts, a challenging job in very tight spots.
Connected rudder cables to rudder.
Made flaired tubing to transition the output from the pitot tube to nylaflow tubing.
Began running wire through left wing conduit for aileron trim, pitot heat, nav lights and strobes.
Tail completely finished
transition from flare to nylaflow
Rudder cable
S6-S Home
LNC2 Home
LNC4 Home
6961
Aircraft Kit
Assembly
Doors
364
526
374
Flight controls
Flight controls
Fuel
697
1545
Hardware
Hydraulics
Instrument Panel
25
241
Insturment Panel
Misc.
758
Panel
Paperwork
Weight & Balance
1136
