Louies Web Site
Date:  1-9-2012
Number of Hours:  2.50
Brief Description:  EDIS 2 wiring
Determined how the EDIS 2 coil driver wires should be connected to the EDIS 1 coil wires. The EDIS 2 will be timed 120 degreees later than EDIS 1 so the coil driver outputs have to be advanced by 120 degrees to keep the correct firing order. Connected the EDIS 2 wires at the terminal blocks for tehinterconnect.
