Connected the Dynon EMS-220 to the fuel pressure sensor, and oil pressure sensor. Ran the ground wire for the fuel flow sensor. Partly completed the wiring from the primer push button switches to the primer solenoid. Connected the fuel pump #1 and #2 wires to the fuel pump select switch.
