Began work to connect the King KT-76A transponder. Figured out how the Dynon altitude encoder converter should be wired to the transponder connector. Began removing the existing contacts from the existing connector housing. Having some problems getting the connectors out without damage to the housing. Re-routed some of the wire bundle from the 37 pin main harness plug from the Dynon SV to make wiring connections easier. Researched a source for a replacement KT-76A connector housing. Found that they are no longer made. Researched connections needed for the Dynon SV Main connector and the EMS-200 unit.
