Fabricated the 0.050" thick aluminum mounting plate for the Endurance bus main feed isolation doide. Mounted the diode. Fabricated a 10 A (18 AWG) fuse link for the Endurance bus main feed. Connected a fuse holder for 20 A fuse in the Main bus feed line. Connected the 12V (2 AWG) cable from the master solenoid, and the wires to the Main bus, and Endurance bus main feed to the firewall feed through. Labeled all wires near each connector, and the Main bus fuse and isolation doide. Connected several ground wires to the common point ground connection at the firewall.
Main and Endurance bus connections
Main and Endurance bus connection to +12V at firewall
