Completed the ignition component shelf. Installed it behind the firewall. Mounted the two Ford EDIS-6 modules and the two Megajolt timing controllers. Mounted the MAP sensor for the Dynon Skyview. Mounted the USB port access socket to the instrument panel below the DYnon.USB port access needed for the Skyview.
