Routed mic and headphone jack cables through the rubber grommet beside the pilot seat back. Soldered the wire to the jacks and put shrink tubing over the connections. Fastened teh jacks to the panel between the seat backs using the supplied hardware. Installed the 12 volt power receptical. Connected 14 ga wire to the receptical terminals using push on ends. Put small cable clamps over both the 12 V power receptical wires and the mic and headphone cables. Fastened teh cable clamps to the bottom front of the baggage storage area. See picture
